an unknown event in gas turbine
We see that in our turbine which is running at 100 % load suddenly switches to lean-lean mode ( 20-40 % load ). Have any body seen this type of issue, or waht are the sensors that are needed to look into to diagnos this issue.
thanks
thanks
RE: an unknown event in gas turbine
also... first thing is call the OEM... if you so require they will send a field engineer to troubleshoot the problem...
these load swings are not good for the unit at all and will damage the combustion hardware very fast.
saludos.
a.
If you are using your terms correctly in saying "Lean Lean Mode" You have a GE Unit most likely with a DLN 2.0 or DLN 2.0+ Combustion system.
Lean Lean Mode is a diffusion mode where gas is being directed to the Primary Fuel Nozzle and the Tertiary Premix Fuel Nozzles.The Gas Turbine runs in this mode from approximately 81% speed to the engine reaches TTRF1 (combustion reference temperature) which corresponds to about 40% base load with extended turndown options and 70% base load without extended turn down options.
The unit will experience what is called a "runback" from Premix to Lean Lean if some event ocurrs in the combustion operation. DLN 2 and 2+ should be giving alarms that will acompany these events.
Can you provide details on the alarms present? Would also help to know if you are runing a Mark V or Mark VI Control as they are completely different when troubleshooting.
Romefu12
What is the maximum temperature a gas generator bearing can withstand. I believe that the gas generator bearing is for a Rolls-Royce Avon engine for industrial engine.
CAE MANIAC
You need to start a new thread to post your question. One you start a new thread comeback and red flag this post.
Please do not hijack another's thread.
