Bypass flow control
Bypass flow control
Hi Folks,
In our R&D test facilities we require water at very low flowrates (10 - 300 kg/h) and high pressure (50barg) for a series of experiments. We plan to use a CAT piston pump with VSD. However we still cannot achieve the lowest flowates (10kg/h). Therefore to achieve the lowest flows I plan to fit a bypass system on the pump outlet. I know this will be a waste of energy but it's research work only and won't be used that often.
My question is where does the throttling valve go. On the main line or on the bypass line? My thoughts are that it should go on the main outlet line, as that is where you want to control the flow. But my colleague thinks it should control the bypass line.
*Note: there will be an oval gear flowmeter on the main outlet to measure the flow.
Thanks in advance
Andrew
Thanks in advance
Andrew
RE: Bypass flow control
Good luck,
Latexman
I think the water pressure will be controlled by the pump, so I will only require flow control. The water is being injected into a steam line (at pressure). The positive displacement will just pump against the resistance from the steam line. So I was led to believe the pressure will just 'sort itself out'.
Does putting in a bypass system mess up this self adjusting pressure control from the piston pump?
If you put the valve on the bypass line, as you say "the pressure will just sort itself out". Control of the bypass valve still needs to be integrated with the VSD though. Valve control might best be done only once the VSD hits the lower limit of its speed.
It's only an R&D lash-up so we will control the bypass line by hand.
Andrew
BigInch
-born in the trenches.
http://virtualpipeline.spaces.msn.com
If the difference is small there would be no problem in putting a flow control valve in the pump line. A small pressure drop could be lived with..?
If there is a big difference in the flow rates, I would put a big valve in the by-pass line. Start with it fully open and then close it until you get the flow required through the process line.
This is all assuming that the usual safety features are installed to prevent excessive pressures.
The pump has a built in safety valve, also the pump outlet feeds water to a heat exchanger which has another safety valve on the hot water out incase of plate rupture.
Andrew
Most of our applications are multiple destination feed points. We've used a CV in the by-pass line to control pressure and a CV in the main line (at each destination) to control flow for many, many years. If we have a system with a single destination, we set it up the same way. Same control code and everything, because one of these days someone will want to tap into the header and use it somewhere else! And, we always put a spare nozzle in the header and a flanged off line run tee at the end of the line.
Two valves on a recip is not asking for trouble if you know what you are doing, but I agree that it is, if you don't.
Good luck,
Latexman
As stated above, a PD pump will flow what it flows. The needle valve will control flow to your test, and the control valve will ensure the pressure you need and automatically dump the required additional flow.
Note: the bypass should not go directly back to the pump suction or it will start heating up the fluid. It should go back to the suction vessel, or be dumped to drain depending on the set-up.
BigInch
