Python Scripting - for element info
For the ABAQUS Experts out there,
I have written a small pyhton script that loops through all the elements in the model and writes out the nodal coordinates & element connectivity for each element. However I am not able to get the material number assigned to each element.
What scripting commands should I be using to query for the material number associated with each element? I would really appreciate it if someone out there can let me know how to do this.
regards
BV
RE: Python Scripting - for element info
You obtain the material via the section object.
Thus, you need to extract the name of the section.
Then:
from model:
model=mdb.models['My model name']
section=model.sections['Section name']
material=model.materials[section.material]
from odb:
import odbMaterial
import odbSection
odb=session.odbs['my odb']
section=odb.sections['Section name']
material=odb.materials[section.material]
For the odb case you need to obtain first the section assignment object.
Each odbInstance in the assembly has a sequence of
section assignments:
   instance=odb.rootAssembly.instances['my odbInstance']
   assignments=instance.sectionAssignments
each section assignment has 2 attributes:
set_i=assignments[i].region -> an OdbSet object
section_i=assignments[i].section -> a Section object
the OdbSet has an array of elements which you can be iterated (i.e. set_i.elements)
xerf,
thanks for the insightful reply. I have few questions however.
1. I am not using the odb to get this information, all i am doing is using ABAQUS as a pre-processor to get my mesh information, which I am writing out to a seperate file and solve it uisng a coustom code. So, instead of using
  " instance=odb.rootAssembly.instances['my odbInstance']"
can i use
  "instance= mdb.models['my model'].rootAssembly.instances".
2. By using mdb instances, will there still be 2 attributes you described for each section assignment, and what should I be looking for instead of the 'odbSet'.
3. Fianlly, where can I find all this information? I have looked up the ABAQUS scripting documentation online and couldnt find what you told me. I would be grateful to you if you can point me to some extensive source I can look up before posting my questions online.
regards
BV
1.instance= mdb.models['my model'].rootAssembly.instances['instance name']
2.odbSet is an object (class) associated with the .odb output database file, therefore if you are using CAE only as pre-processor you do no need odbSet.
In ABAQUS Scripting Interface (ASI) there are two main classes:
(i) mdb storing the pre-processing info
(ii) odb storing the post-processing info
Any class having its name starting with "odb" relates to the output database and to an odb object.
If you are using CAE only as a pre-processor and you are not convenient with the architecture of the ABAQUS Scripting Interface (ASI), a simpler approach would be to write the input file and extract the information from the input file (.inp) which is a text file.
CAE->Job module->Job Manager ->Write input.
The input file should be very easy to parse (especially if you are using Python) and it is prety much self-explanatory.
3. For ABAQUS Scripting Interface I use only "Scripting Reference Manual". To become convenient with the ASI structure , I think, one should start with the "Scripting User's Manual".
