PVC & UL 94 flammability
Does all PVC meet V0 requirements as set forth by UL 94 due to its self extinguishing properties or does it depend upon formulation/usage e.g. extrusion, molded, etc.? I know that additives are often used to make a thermoplastic meet the requirement but I'm not sure if the PVC that is V0 has these additives or not.
How does one go about ensuring this requirement is met?
RE: PVC & UL 94 flammability
You could have a part tested.
PVC is normally a compound that contains additives to improve it's mould ability. These could be detrimental to pure PVCs natural inclination to be flame retardant. I am not sure if PVC needs the help of additives to get a V0 rating.
