Batch Heat Transfer
Batch Heat Transfer
I have a rectangular rail car that has a batch of vessels inside with fluid. Outside of the rail car is insulated with 1/2 pipe coil on each side(not on ends or top). Water or steam will be pumped through the coils to heat the fluid in the vessels. The fluid is not agitated and it will remain stationary on the car during heating. How can I determine the appropriate heat transfer coefficient for this and determine how long it will take to heat this up reasonably?
RE: Batch Heat Transfer
In what heat transfer class or text book did this homework problem originate?
StoneCold
Process Heat Transfer by Donald Q. Kern
saludos.
a.
