Vapor Liquid Barrier
Is there any technology on the market that will stop or re-direct vapor while still pumping liquid?  I am trying to design a system for naptha...
RE: Vapor Liquid Barrier
How about a two phase separator tank?
That is a possibility, but the Proc Engr thinks there is some sort of "probe" technology out there.  We are unlaoidng napthat from trucks through aprox. 1200 ft of pipe to tankage.  About 4 fps.
SETxG,
Can you explain what you mean by "stop or re-driect vapor while still pumping liquid", or expand upon it.
How will "some sort of probe technology" do the same thing as a separator?
I'm a bit fuzzy on what the application is.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
