part mating sequence/coding
What is the best method for determining a part mating sequence.  Such as, (ie..)48 different, or final, parts use a combination of 3 components, which could be interchanged to produce wrong parts.  Would like to use mating pins and cleanace holes.  Is there an easy method for determining the combinations of holes to pins?
