NEW WATER TREATMENT SYSTEM
I am currently the engineer on a project in which a new water treatment system is to be installed.  The treatment system will have chlorination, fluoridation, and iron removal.  We are also revising the existing gaseous chlorine feed to be a liquid chlorine feed.
I am trying to track down some specifications on these topics to have a sort of starting base point for the final project specifications.  Does anyone have experience with this or know  of where I may find specs for this type of project.  Thanks in advance.
RE: NEW WATER TREATMENT SYSTEM
Yes.  Go to our Web site and click on "E-quest".  Fill out the questionnaire and we will generate the specs you need based on the information that you supply.
S. Bush
www.water-eg.com
