save bug help....
save bug help....
save bug help....
currently I'm working on a drawing for my scenior engineering design...I got to a point where everytime I try to save, pro_engineer just crashes and I'm unable to reopen the file...the single file is made of 34 sub files..I deleted the sub_file #34 and I was able to retrieve and open the drawing...The drawing contains a mixture of solids, curves, and surfaces. Everytime I creat  a new boundary surface and try to save it pro_eng crashes!!!.
I'm stuck, I cannot go any further with my drawing...
Heeeeeeeelp!!!!!!!!
RE: save bug help....
Hi
I assume you are using ProE2000i2, I had this problem as well the only cure is a later cut of software. I am not able to tell you which cut cured this problem (I am not at work) but I recieved it in november. I hope this helps.
Andyb
