How to run NX from home?
Hello folks -
I was wondering if there is a simple/realistic/reliable way to access my NX4 data residing in TCe from home.
First a little background...
I have a very reliable 3 Mb DSL connection, and can connect to the company network via an SSL socket.
We have just deployed TCe 9.something, and our non-remote data resides on a server that is about 10 miles from my home.
In general, I would not be looking to work on large assy models - just want to be able to load a model/drawing file and putter a few hours per night when I get behind.
I'm thinking that rather than install TCe at home and connect to the live data vault, it might be better to export what I want to work on, bring it home on a flash card, then reimport it the next day.
Is there a safe/easy/reliable way to move data in and out of the vault? Is it unrealistic to expect to connect to the vault via a SSL connection on a 3 Mb line? Does NX automatically version any data that is exported/updated/imported?
Any suggestions or comments appreciated.
Disclaimer - I have used TCe for about 3 days now, so what I don't know about it would fill volumes.
Thanks for any help...
Ed Acciardi
Ed Acciardi
RE: How to run NX from home?
Connect to your work via a VNC or other remote login software.
Install NX at home and point your license variable to your work license server over VPN, and use Teamcenter Web to download the files and upload the files or you could export the data from teamcenter bring it home and work then import it again.
Non of these are the best options, latency will kill you. Physical distance to your work does not exactly mean a smaller bounce or less latency issues.
-Dave
PLM Exchange
http://plmexchange.net
http://groups.google.com/group/NX_CAX/
Keeping the NX license active over a DSL line should not be a problem. I did this in Wildfire all the time and it was a no-brainer.
Would I have to export all the data objects in the item's container?
Thanks again...
Ed
If you are working on an assembly it gets more difficult, but if you have the naming rules set up correctly it shouldn't be too difficult.
definitely start with a single piece part. Teamcenter 2005 SR1 would make this easier with the 4 tier architecture.
-Dave
PLM Exchange
Ed
-Dave
PLM Exchange
Ed
-Dave
PLM Exchange
It's a new terminal-server software from HP for demanding graphics applications. We haven't tried it yet, but we will in the near future.
Anyone having experience with it?
Mik
Ed
-Dave
PLM Exchange
But the software does perform as advertised. You can rotate the shaded solid image at perhapes 2 frames per sec. I reduced the graphics quality to 20 (out of 100) for faster rendering. ANything less than 20 and text becomes illegible.
Thanks for the pointer.
Ed
-Dave
PLM Exchange
I don't understand...what is "4 tier mode" with Teamcenter? I have really good refresh rate with Windows XP and remote desktop connection at home to my workstation at the office but NX2 will not show the graphics area of the screen. I am forced to switch over to a Dameware client (similar to the HP software mentioned above or a NetMeeting type application). Can you explain 4 tier mode to me? I would love to get this to work.
Andy
The reason why your remote desktop won't show the graphics on the screen is probably due to high graphics demand NX requires and Remote Desktop just can't or won't support. There was a similar issue with NetMeeting and you had to turn your hardware accelleration all the way down (on your Windows O/S setting).
Also if you want Remote Desktop to work try true color setting (I think that is the setting).
-Dave
PLM Exchange
