3D Label Library
3D Label Library
Is there any place on web I can get safety label models for free?
It is not like it's hard to build own, but if somebody already created them...
RE: 3D Label Library
You may need to create yourself.
Here is a start.
http://www.cadresource.com/library/symbols.html
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-06)
Go Here: http://www.zxys.com/swparts/
Best Regards,
Jon
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
http://solidworks.carbonmade.com/
Solidworks 2006 SP4.0
RFUS
http://f
http://f
http://f
Could you just use the sketch picture or decal?
Chris
AutoCAD 06
I've created label with sketch (part), add it to assembly, it looks nice, but on the drawing there is no sketch, just label part outline. How to make sketch visible? What do you mean "make them into blocks"?
Thank you. Boris.
If you want it inserted onto a model surface, then create it as a feature/part or insert as picture.
Chris
AutoCAD 06
Thank you.
