Sizing a Parcel to specific Area/Square Feet
Say I have a parcel, 4 sides already exist its, its about 5 acres. I want to cut out a piece that is exactly 4,000 square feet. And I know what two sides I want to use to cut it out. I read the help file about slide bearings ect., tried it and can't figure it out. Anyone know the best/easiest method for doing this? Its illustrated in the help file but I still dont get it! Autocad LDD 2004
jim
jim
RE: Sizing a Parcel to specific Area/Square Feet
The polygon is 4 sides. You know two sides. You will have to end up with a rectangle and two triangles. Start with a rectangle that best fits the area you want to subdivide. Place that, then form the two triangles around it. find their combined areas. I would guess that with 2 or 3 iterations, you will have your parcel exactly the # of sf you need.
Engineering is the practice of the art of science - Steve
