Garbage room
Garbage room
I need to cool a garbage room so as to reduce odor due to spoiling of organic matters. What is the internal garbage room temperature I should be designing for? The garbage is taken out once daily, usually at night, to a dump site.
Please indicate which refernece is used to obtain the information from
RE: Garbage room
pls see www.hvacmall.com
i think you will find materisl or help from there also.
thanks
RE: Garbage room
RE: Garbage room
The unit was sized at 150 square feet per ton.
The thermostat is set at 60 deg F.
The unit runs 24/7.
The walls and ceiling have R-30 insulation.
Be sure to have a floor drain and a hose bibb in the room to wash the room down everyday.
RE: Garbage room
RE: Garbage room
Thanks for the info.
What are the numbers based on ?
RE: Garbage room
RE: Garbage room
If the garbage is removed once daily, I wouldn't focus on AC so much as exhaust ventilation. No scientific evidence to back this claim, but bacterial growth between a 60°F room and an 80°F room probably wouldn't be orders of magnitude different in a 24-hour period. With a daily turnaround of trash from this space, a majority of growth might occur at the various points of origin of the trash rather than the dumpster location.
Current standards for exhaust for odorous or potentially hazardous areas is 1 cfm per square foot, and you will want to make up air at about .8 cfm per square foot to keep the space negative relative to surrounding areas. Most of these areas I've seen are in loading docks or areas where room conditions (e.g., open bay doors) would preclude full air conditioning.
I agree with provisions for drainage and a daily wash-down.
RE: Garbage room
On my job the trash room backed up to the pool deck so exhausting the room was not an option.
