Low coeficient of friction plastic
I require a plastic with a low coeficient of friction which I can use as a wear strip underneath a rubber belt conveyer that will not build up too much heat. The rubber belt moves at 0,5m/s.
RE: Low coeficient of friction plastic
For a place to get adhesive PTFE tape look here:
http://www.cshyde.com/Fat%20PTFE%20Tape.htm
They have more or less everything you could need and can advise you as well.
