Dependence of pressure on viscosity of air
Hi all,
I'm looking for a formula, graph or explanation which describes the viscosity of air depending on the pressure (1 atm until vacuum). Can anyone join this information?
With kind regards,
ME
With kind regards,
ME
RE: Dependence of pressure on viscosity of air
At these low pressures http://webbook.nist.gov/chemistry/ gives for nitrogen an oxygen at 25 deg C, 17.8 and 20.4 μPa, respectively.
Besides, your conversion from mBar to psi has an error by a factor of 10.
P (psia) Viscosity (lb/ft-hr
1.5E-08 0.04410
0.001 0.04410
1 0.04411
3 0.04412
5 0.04412
10 0.04414
20 0.04417
50 0.04425
100 0.04438
200 0.04467
500 0.04567
1000 0.04771
2000 0.05287
3000 0.05901
5000 0.07238
8000 0.09182
I should have written μPa.s. The link I gave above gives the viscosities for nitrogen and oxygen over the full range of pressures and temperatures.
As indicated by iainuts, it appears that -at constant temperature- the required high vacuum diminishes the dynamic viscosity at atmospheric pressure by about 1%.
The kinematic viscosity, on the other hand, being the ratio of the dynamic viscosity (kg/m.s) to density (kg/m3), and expressed in m2/s (or cSt), changes a lot with pressure.
