Can I measure Water Hammer?
Is Water Hammer the resultant "Noise" from the shock of acceleration of water? If so, Water Hammer is nothing more than vibration.
Is there a point when Water Hammer is pressent and not detectable by the human ear? If so, would there be any damaging affect because of the seemingly small amout of Water Hammer?
Is there a method of measuring Water Hammer?
Darrell
RE: Can I measure Water Hammer?
No, it's not the resultant "noise." It is also much more than vibration.  A water hammer is a "layman's term" for a pressure transient, often severe, usually caused by fluid rapidly changing direction in a non-full pipe.  Just accelerating the fluid doesn't do it, you also have to rapidly change the direction of the fluid. Having a partially steam filled line with a rapidly increasing pressure also adds to problems.
Yes a water hammer can be present and not detected by the human ear IF THERE IS NOBODY THERE TO HEAR IT.  It depends on how close people are to the location of the water hammer and what intervening material (distance, amount of concrete, etc.) as to whether someone will actually "hear" it.  And yes there could be damage, even if no one hears it. You can often "see" the after-effects of a water hammer by the line of dust on the floor that was shaken off the pipe. However, the major concern is with the pipe supports that might be damaged.
Generally, you want to design against it, because of the very large pressure transients which can occur.  However, if you think you have it going on, then some high-speed pressure gauges and accelerometers would allow you to measure it.
Why do you think it is water hammer and not cavitation?
Patricia Lougheed
Please see FAQ731-376 for tips on how to make the best use of the Eng-Tips Forums.
Its about as much like vibration as an earthquake is.  Water hammer is often not heard at all.  What is typically "heard" is the effect of a pipe moving into a support or slamming up against a wall, anchor point or other supporting structure, if not actally coming lose from its mountings, or breaking up a flange joint completely, if it was severe enough.  If the support structure was not there, the pipe might even have moved relatively silently, and probably moved a lot more.  The event triggering the high pressure transient in one place could have originated 20 miles or more away from the point of observation.  They are quite common on long pipelines with high fluid velocities that experience rapid +/- accelerations.
BigInchworm-born in the trenches.
http://virtualpipeline.spaces.msn.com
BigInch (Petroleum) Velocity in long liquid lines does not have to be high to cause water hammer problems.  Consider what the unbalanced forces are due to changing the velocity by say 5-6fps.
regards
5-6 fps is also a fairly high velocity in a pipeline i would say. I know you can go double that velocity but it not a requirement.
Best regards
Morten
MortenA (Petroleum)5-6 fps may be high, depending upon what system the flow is in.
At any rate, Try 1-2 fps change in velocity in a long pipe and I believe you will see the resulting unbalanced forces are relatively high.
Sailoday28: I agree.
BTW going back to the original question: I believe that you can get both electronic pressure gauges that are fast enough to catch the peak pressure and mechanical gauges with "stickyness" so that the gauge wont drop back but stay at the max pressure.
Best regards
Morten
MortenA (Petroleum)While fast response devices are available and can be used, why not design to minimize the potential impact of "fast/slow transients"?
 What seems to be a slow closing valve is relative. In a long pipe, such a valve can be considered fast closing.
For example, neglecting friction and flow velocity, and say 2 miles of pipe with a sound speed of 3000fps- under 3 seconds closing time is fast.
When I suspect pressure spikes in a hydraulic systems I put a pressure gauge in the suspect line with a check valve in front of it, free flow to the gauge. When a pressure spike occurs the gauge will see it and the check valve will hold it. It usually takes a couple of hours to finally trap the spike pressure or at least near its maximum.
Bud Trinkel CFPE
HYDRA-PNEU CONSULTING, INC.
fluidpower1 @ hotmail.com
http://www.fluidpower1.us
budt (Industrial)I follow your reasoning, but the gauge reading is now dependent upon the response time of the check valve.
regards
I would like to thank all of you for the informative conversation.
I think it is time to give a little background.
I am building Valve/Actuator packages and I would like to design into the actuator a closing profile which slows the closing time toward the 100% close position. I have a fellow associate who feels that it isn't necessary.
The velocity in an 8” pipe with the valve fully open is approximately 20 ft/sec^, and the length of pipe varies from 50 ft to 500 ft.
From your comments, it appears that I should press forward with a closing time profile.
Of coarse I would like to eliminate the complexity of the closing time profile, so If I were to build a prototype and test it for water hammer, and found that there isn’t a need to change the speed of the valve’s closing, everyone would be pleased. But, I would need a definitive test method to determine the amount of water hammer.
sailoday28 wrote:
"budt (Industrial)I follow your reasoning, but the gauge reading is now dependent upon the response time of the check valve."
I know its not perfect but gets close enough with available inexpensive equipment. It is also a way to get info without the machine operator or others knowing you are checking.
Try it, you might like it.
Bud Trinkel CFPE
For pipelines 5-6 fps is normal, typically 3 minimum and 10 maximum.
A 3 second total closing time on a pipeline is speed of light, 1 sec/inch being more reasonable, unless its an ESD valve.  Great care is needed in selecting valves and actuators when velocities are above 5 fps, as many valves effectively open in the first few seconds, or close in the few seconds, even though their total opening time and closing times may be only 1 sec/in diameter due to poor Cv vs actuator position curves.  One must be carefully in slowing down the mainline velocity well before a valve gets close to its shutoff point.
If there is a snap acting gas operated ESD valve in your pipelines, you must do a transient analysis.
This type-ahead (of brain) is killing me.  Make that 1min/1 ft diameter (5 sec/in-D)
BigInch (Petroleum)"A 3 second total closing time on a pipeline is speed of light,
Depends on time for inital reflection and responding reflection to return to point of origin.
For a short  lengths, 3 seconds may be a slow closure.
I agree biginch - to me this sounds more like "piping".
The Jucowsky equation give a conservative estimate:
h(wh)=a*dV/gc
where
a=sqrt(1/((den/gc*(1/K+D/(bE))
Keep it strictly metric and it all works out (head in metre liquid column)
gc:gravitational acceleration
V:velocity
K:bulk modulus of elasticity of THE FLUID
E:bulk modulus of elasticity of THE PIPE
See e.g. Perry for reference
Best regards
Morten
oh yes: The (origina) question was really just about measuring water hammer pressure - not preventing or predicting it...
Best regards
Morten
In the above, a 3 second transit time would probably not be acted upon at all if the valves had a closure time of 25 seconds, so the max transient pressure for that event would (hopefully) have to had been below the max design pressure, which is why a transient anlaysis should have been done beforehand to verify that indeed it would have been.
Caution, the Joukowsky equation is for a straight single level pipe filled with one product and closed on one end, so it does not tell the whole truth when applied to an operating pipeline that typically will cross one or two mountain ranges and river valleys, maybe with slack flows, wide variations in product density (due to +2800 meter differential elevations), or perhaps 10 products in the line at the same time, have open connections into other systems, pumps starting, stopping, check valves chattering, and control valves changing %Open at several (or many) points along its length and have multiple reflected (algebracially additive) transient waves moving back and forth between stations.
Biginch i always considered Joukowsky to be conservative. Is that not the case. Can columseparation and following cavitation cause even higher surges?
Best regards
Morten
BigInch (Petroleum)"Caution, the Joukowsky equation is for a ......"
The Joukowsky equation is not limited to a pipe with a closed end. If used properly, it can include the effect of disturbances such as valve closure or opening as a function of time, the movement of a pig in a pipe, etc.
The stated equation,is an oversimplification of the results of the method of characteristics. In the form presented, it does not include friction.  However, in rapid transients, friction is generally small, compared to the acceleration effects.
In addition to neglecting friction,the Joukowsky equation  should only be used with highly incompressible fluids (and further assumes sound speed does not change).
The method of characteristics is the way to go for general solution of one dimensional transient flows of a homogeneous fluid.
Yes of course.  What you describe is effectively, instantaneously in time, the same as "a valve with a closed end", a pipe cap, or a partially open valve if you prefer, a reducer, and expander, a 90ºEll, anything that has the capability to set up a change in velocity, whether it is a pig, a closing valve, or a closed valve, all means the same thing in the general sense.
Actually, there are valves that can close a lot aster than indicated above. And they do lead to  significant pipeline overpressure events and end reactions.
In the electric power industry, the main steam stop valve at the turbine inlet is a 12" NPS electro-hydraulically actuated valve, fail closed, that will close in 0.2 second total stroke time. Similar speeds are assocaited with the turbine bypass control valves. While the bypass control valves may haev a reduced speed of closure to  limit steam hammer events, the turbine inlet stop valve has not such limits, as its objective of preventing turbine overspeed has a much higher importance than pipe reactions.
There are also other specialty stop valves that close faaster than 0.2 secons- I recall that Target Rock stop valves ( used in nuclear subs) advertise a much faster closer speed.
BigInch"What you describe is effectively, instantaneously in time, the same as "a valve with a closed end.....",
No it isn't,  If the valve closes say 1/2 way prior to the first reflection coming back, the full instantaneous pressure is not reached.
Yes, I agree, its only a partial reflection in that case.
Please don't think you must describe reflections to me.  I may not describe things in a detailed manner that you can easily understand what point I am trying to get across, but in any case, I can see them quite well during the simulations I am working on, so no need to bother yourself.
Back to Morton's question.
The Joukowsky equation can underpredict the maximum pressures in certain cases.  I often find 10% differences in simple cases, where equipment interactions are not considered.  This is due to line packing effects, after the fluid has effectively stopped forward progress, the pipeline begins to expand due to the higher pressures, allowing more fluid into those segments and small forward velocities persist.
Other errors are common in the use of the equation.  For example, a water pump station, 20 miles of flat pipeline, a 1000 foot elevation climb in 5 miles with a pressure on top of -5 psig, followed by a uniform decrease in elevation over the last 20 miles to the terminal, which is at the same elevation as the pump station.  Flowing pressure at the terminal is 125 psig with a velocity of 6.8 fps.  If the terminal's ESD valve closes, what is the maximum predicted pressure at the ESD valve inlet?
When other factors are considered, where velocities may go higher than design velocity, a higher percentage error can occur.  Just a valve opening too wide at a terminal downstream from a 3000 foot mountian may reduce the mountaintop pressue to the product's vapor pressure and create a runaway column.  It would have to be stopped at its maximum velocity, which might be as much as 4 times the design fluid velocity of 5 fps.  A Joukowsky prediction would give only the pressure increase based on the 6 fps velocity (400 psi), and the actual pressure that might be seen at the terminal could be as high as maybe 1750 psi.  The 400 psi, would have to be added to the full static pressure at the terminal (1300) to come close to what would actually be seen at the terminal, 1750 psig.
OK - so in then last example it would be the velocity that was too low - not the surge pressure predicted as such?I would always ad the head predicted by J. to the "steady state" pressure - do you by static mean the max. elevation difference?
best regards
Morten
Right, to approximate what I believe can give an approximately correct answer (I'm not sure, as I haven't yet justified that assumption by any physical relationship), but yes, you would have to add the J. equation dH results to the static head (head & pressures at zero pipeline flow) to approximate the results I typically get for run-away columns.  This is not adding the J dH to whatever happens to be the steady state operating pressure at the station inlet before a valve closes.
The results for the example I gave above, I think were from a case I ran for a water column running away from a 1000 foot head in a 20 mile long 30 inch diameter pipeline.  I recall seeing a velocity of about 20 fps before the valve responded and increased the pipeline's outlet pressure sufficiently to start slowing it down.  So, there's nothing to say the velocity might have not gotten higher.
Perhaps a safe conservative result could be found by using the maximum velocity attained by dropping an object from the pipeline's high point elevation to the inlet elevation + minimum inlet pressure head equivalent, but that would be way too fast to give any useful result.  Seems that frictional resistance and a terminal velocity must be determined in order to yield a useful velocity.
Do you have some thoughts on how to find the "terminal velocity" for a run-away column?  Maybe using an equivalent spring derived from the products average bulk modulus???  For me, its easier to do a sim.
BigInch I'm not completely following your explanation but the
The Joukowsky equation can be modified for highly incompressible fluids where flow flow velocity is low compare to sound speed as
a*delta U+delta p/rho +(or -)delta z=0
where a is sound speed, U is velocity, pressure, rho density and z elevation.
Note friction is not included.
What do you mean by run away column?
The current topic is,
"Does the Joukowsky equation give conservative results and, if so, is there a partiular manner in how it must be applied to give conservative results?"
I believe that it does not give conservative results and yields pressures that are (at least) 10% lower when pipe expansion and water compressibility are considered. I have compared the differences using water only.  Will a more compressible product, say for a bulk modulus of 2/3 that of water, such as diesel or gasoline, result in even a greater difference than what is seen for water?  I have never compared the results from J. eq. for any product other than water.
A run-away column happens in liquid pipelines.  It typically results from reaching the vapor pressure of the fluid the highest (or a local high) elevation point of the pipeline.  When reducing pressure, and upon reaching vapor pressure, no further pressure reduction is possible, as any liquid in the low pressure segment vaporizes to fill any increasing void space.  With the "siphon" effect lost, liquid on both sides of the mountain peak could accelerate down the sloping pipeline, due to gravity, if the inlet and outlet pressures drop for some reason or are not brought up to equal the static pressure plus that required to stop acceleration.
So the question now at hand is, "What velocity should be used with the J eq. to give conservative results for a run-away column condition?  Or, in other words, what is the maximum velocity attainable in a pipeline (or any column of liquid) with only vapor pressure at the top, and to be conservative, with atmospheric pressure at the bottom, accelerating due to gravity, within a vertical or sloping pipe of length X?
In the few cases I have actually compared (using water), I have seen that the J eq. resulting dH, calculated using the pipeline outlet velocity predicted by my simulations for a instantantly closing valve at the outlet, must be added to the liquid column's static pressure to approximate the maximum pressure at the closed valve that is predicted by the simulation, but it is still a little low when compared to the simulation result.
BigInch With regard to your first paragraph response.
From the method of characteristics with a highly incompressible fluid and negligible friction
Utop=0
(Ptop-Pbottom  =rho*c*Ubottom +  (Xbottom - Xtop)*rho.
See below for derivation.
Generally for liquids, sound speed>>velocity of fluid.
If sound speed is based on rigid pipe, then results should be conservative. If liquid is single phase prior to closure of valve at top, then liquid should not flash in uphill portion.   Down hill is another story.
Is friction important? It can be, however, at best most of us can only use an approximate friction factor which is based on steady state, not transients.
I would suggest that if transient pressure rise or reduction compares with the initial steady state friction, then somehow, friction should be included.  If transient pressure rise>>friction, then neglect friction.
The dearivation below can include friction, however, I have left it out just for simplicity.
du +dP/(lambda *rho)+dt=0   where u = velocity, P= pressure, rho=density  t, time and
lamda = +(or -)sound speed
Or
du +dP/(lambda *rho)+dX/(u+ lambda)=0
 where dX/dt =u+lambda
                 and X =distance in flow direction
With flow uphill to an instantaneous valve closure at top of hill
u+ integral dP/( (lambda *rho)+ integral  dX/(u+ lambda)
=constant
assuming constant sound speed and small velocity compared to sound speed along with negligible change in density.
Utop -U bottom +(Ptop-Pbottom)/(rho*c)+(Xtop-Xbottom)/c=0
Utop=0
Biginch: There is an article from 95 on the subject of slack flow by R Edward Nicholas. He also calculates the velocity in a slag line region as a function of the "full line velocity" - but im not sure thats the same - since slag flow as such is not "run away" but something that occurs in steady state.
Its found in the PSIG website where many other articles also can be found. This is a link to the article mentioned:
http://www.psig.org/papers/1990/9505.pdf
Best regards
Morten
I believe I call "slag" flow "cascading" flow, actually a form of open channel flow in a closed pipe.  In that condition, flow underneath the gas pocket becomes faster, since there is less cross-sectional area for the liquid to travel within.  The next step is dragging the vapor pocket to some point down the hill, maybe bubbling some of it back up the hill again if the flowrate is small enough) until pressure goes back above the vapor pressure, or continuing at low pressure and starting to develop two phase flow regimes.  While sometimes used as a low flow mode for single product pipelines, low pressures can be a really bad situation if you are flowing multiple products and an interface between two products passes the gap.  You can wind up with a very very long totally unhomogeneous mixture.
thats what this article is about (although he calls it slack flow - checked the spelling) Check the article i found it interesting.
Best regards
Morten
Sorry english is not my mother tounge - bownout=loss of power? Are you referring to e.g. a pump trip and following collumn separation? This is a common situation i agree. The article deals with a "steady state" situation when pumping.
Best regards
Morten
No ...brownout to my brain.. insufficient power to the abstract thinking neurons.
Slack flow can happen during steady or transient situations.  Usually, if steady state, it represents the minimum flow operating range for a pipeline, as for an oil pipeline (such as Baku-Tbilisi-Ceyhan) from the Caspian region where only a 100 MBOPD production from the first few fields is being transported now, but the pipeline's maximum design flow condition will be reached during the next 5 to 10 years, when the pipeline share of the region's production could eventually reach 1 MMBOPD.  During the first few years, only a very small pressure is needed for the 100 M flow abd slack flow operation requires the least power.
If its a transient situation, it was probably created by a trip of an upstream pump station and the line is still flowing and rapidly dropping pressure at the high point.  Could also be caused by an outlet pressure control that went below normal outlet pressure settings when somebody turned up the outlet flow too much.  If the pressure is increased too rapidly during recovery, the collapsing bubble of vapor can make for a really large pressure spike as the two columns impact each other as the vapor re-condenses.
Our SCADA system was fast enough on a 200 Mile line to see the water hammer
When the valve shut at the customers end, a pressure wave started back toward the source.  The rate of change alarms went off at each block valve site coming back and we recoreded the pressures.  The block valve sites were 7 miles apart for the ones close to the customer and 20 miles apart as the is closer to the pumping site. The distance was about 100 miles.
The wave bouced back toward the customer but went away about half way there.  The SCADA system updated every 3 to 10 seconds and we had good rosemount transmitters we calibrated quarterly.
The product was high pressure propylene.  The parallel ethylene system would not water hammer, too compressible.
dcasto without having looked into your system i would say that biginch has a point: Surge/water hammer is a phenomena with a much higher trancient resolution than 3-10 seconds. The peak pressure may only last for less than a second. Im sure that i dont have to explain Shannon sampling theory (and being a process engineer im surely not the right person) but i do understand that much: You have to have double the samling frequency compared to the system that you cant to measure (excuse my poor english - cant put it any better).
Best regards
Morten
It might be your recorded peaks were chopped-off versions of the true wave that may have actually missed the high point.  Depends on the shape of the wave, speed ...
We may not have caught the peak pressure as they went by the transmitters, but there is no denying that we saw the wave.  I have set up an ocilliscope on a very sensitive pressure transmitter to read the pulsations from a PD pump trying to prove if the pulsation dampener was working.  We could see the peak pressures that the transitters could not record.
This may be off the thread, but there is a sonic wave sent through the system whenever a valve is opened or closed.  The pipeline I refered to above had some test run on this theory by NASA (the line went through Friendswood) and they used highspeed pressure recorders to sense when a valve opened.  Then by listening along the pipeline at different stations and using time differential they could pinpoint the valve opening location.  The application was leak detection. the opening of the valve was a leak.
It worked.  The hold back then was cost of the system. especially the time factor, all the locations had to have exact time to "triangulate".  Today I'd bet they could use GPS to get the time very accurate.
Exxon?  Nobody's denying you can't see them, hear them, or measure them.  Just a question of how well sometimes.  Other times, there's no question at all.  They can make a rather loud bang as they pass through a meter or marine terminal loading station.
Actually there have been a lot of ultrasonic leak detection packages on the market for quite awhile now.  Its claimed they work rather well.
In 1993 for OxyChem, now Equistar,the lines are ethylene. We tried various leak detection models and tyipcal ultrasonic and they didn't work.  We were installing a LIC pressure point analysis type system with a heavy front end processing for SPC of the measurement instruments when I left the company in 1995.  The package even compensated for the hieght of fluid difference between the instruments and the line.  The density ranged from 23 to 8 lbs/ft^3.
The NASA stuff looked promising, but I never knew what happened to it.
From what I hear, there are a lot of fantastic ultrasonic claims that just don't hold water after installation.
The only thing I know that works is a hot real-time transient model comparison to second-by-second data for large leak alarms and detecting small leaks by long term differential volume summation, and following the big blue flies to a gas leak.
LIC is one of the good ones.
My experience has been that you need fast response high accuracy pressure transducers connected to an oscilliscope or a data logger that is capable of logging all the pressure peaks otherwise you will miss the transient. Generally SCADA systems just dont cut it for accuracy or response times.
I demonstrated this to an international oil company when they had transients as shown by the pipes jumping all over the place yet their SCADA didnt pick up the event.
Go to www.ventomat.com and read the articles there on how they developed their air release valve. Ventomat didnt understand the pressures being experienced unitl they used the right gear.
Geoffrey D Stone FIMechE C.Eng;FIEAust CP Eng
www.waterhammer.bigblog.com.au
In response to MortenA,
Joukowsky does not give you the worst conditions. For a start it doesnt predict column separation and the reforming.
Prof ARD Thorley inhis book describes this phenomenon. Also trey Walters in the manual for AFT's Impulse explains why Joukowsky cannot be relied upon.
This is one of the common mistakes in the engineering world. Ignorance is bliss for some as they do a quick calculation and advise their clients that the worst pressure is X as a result of a pressure transient.
When you consider that the piping codes all say that the design pressure shall include surge pressure, this ignorance is unforgiveable. how many engineers avoid surge analysis because it is too hard?
See my papers on  Risks & Surgee at www.pipingdesign.com or www.olaer.com.au/products/water-surge-vessels.htm.
Vent-O-Mat looks like a pretty nice source for air valve info, but must be the slowest site on the web.  I lost patience.
Stanier, do you have a link to Trey's AFT paper?  I couldn't find it.
stanier (Mechanical)I think that Joukowsky will give conservative results when used with the assumptions it was derived for. That is low velocity realtive to sound speed and highly incompressible.
The elasticity of piping should serve to reduce sound speed and with it peak pressures.
Yes column seperation is important and as you state should be considered. As I uderstand it, typical water-hammer anlysis assumes the water-void based on isothermal analysis. That too may not be conservative, since it is possible during an expansion to have flashing and pressure drop in the two phase region as the flashing temperature is reached.
A manual analysis may assume isothermal conditions.  A good transient program will not.  Column separation and vaporization reduces temp in the region, whereas recombination of the columns with associated vapor condensation and pocket collapse releases heat and raises the temp.
BigInch
It wasnt a paper by Trey it was from the Impulse manual. I will get it to you.
Geoff
BigInch (Petroleum)I doubt that the water hammer programs out there can handle adiabatic flow. Whether by hand or computer, isothermal solutions and those using constant wave speed only require the intersection of two characteristics (dx/dt = c and dxdt=-c) to obtain solutions at future times.
With adiabatic and or heat transfer, the method of characteristic equations also require the additonal complication of solution on a particle path ( of dxdt=u, where u is the local velcity).
I'd be interested to know the available programs out there which handle the more complicated MOC solutions.
As a correction to my last post, The elasticity of piping should serve to reduce WAVE speed and with it peak pressures.
You can model the effects with the better programs.  They allow column separation to be accurately tuned to measured field responses, if not entirely rigorously calculated.  The temperature effects act to slow down vaporization on column separation, since the temperature reduces resulting in a corresponding reduction in the vapor pressure and slower vaporization, with the reverse being true upon column collapse when condensation liberates heat, thereby increasing vapor pressure and slowing the vapor condensation. Vapor pressure changes are calculated resulting in corresponding velocity changes in the segments affected.  The timing can be manually adjusted to match field observation.
BigInch "The temperature effects act to slow down vaporization on column separation, since the temperature reduces resulting in a corresponding reduction in the vapor pressure and slower vaporization.."
As an expanding fluid drops in pressure and as you state there is a reduction in vapor pressure. However there is an increase of quality for two phase homogeneous fluids.
What is your basis for slower vaporization?
Also, sound speed will radically change at the point of zero quality and in the two phase region as quality increases.
I'd be interested to know of water hammer programs which handle the varying sound speed for the two phase region.
Let's just say it would be stopped completely if the vapor pressure on liquid cooling dips below pipeline pressure.  I believe it slows between vapor presure and bubble point, but I don't know exactly how rigorous a solution it becomes there and also regarding the quality.  I can't see the calculations or access that detailed data and the manual is not explicative.  The sonic velocity is adjusted.  Suffice it to say that the solution is adequate for most pipeline work.
Send me an e-mail and I can show you what the manual has on it.
