Changing Parts in Drawings
I'm currently putting together a series of sketches from SW to pass onto our drawing office.
All of the parts are pretty similar, just a couple of dim changes between each one.
I was wondering if there is a way to create the first drawing with sections, detail views etc, then re-saving and inserting the other parts as I go while mainting the views and dims?
Thanks.
Thanks.
RE: Changing Parts in Drawings
thread559-166949
Also,
You can use SW Explorer.
or,
Create the part and dwg.
For new parts/dwgs, open first part and dwg above.
Part ... save as new part, then - dwg ... save as new dwg.
Repeat for additional parts/dwgs.
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-06)
Got it, bit new on this so I guess a bit of learning to do!
Cheers,
Graeme
Click on the existing drawing file and then hit the REFERENCES button. When you dble click on the current pathname, you get a normal file menu and you can pick a new reference.
This works on 2006, anyway. Be careful to save the drawing file with a new name.
