Disappearing Sketches
We are currently using V5R14 SP1. We have recently noticed our sketches are disappearing. Our methodology has us using alot of boolean operations, when we add/subtract the solid from the model and step back into the tree to modify the sketch it's seems to be hidden from our sight yet it doesn't appear to be in "no show" either.
What we have found is breaking the part back out of the tree (doing away with the add/remove) and then modifying the sketch we can clearly see and modify the sketch, it doesn't seem to be consistent for all booleans and sketches making it harder to track what's causing the problem.
Does anyone have a solution or experienced this same problem?
thank you in advance!
RE: Disappearing Sketches
Derek
Catia Design|Catia Design News|Catia V5 blog
Cheers
I don't know anything but the people that do.
For one things, it's just a good habit to have things labelled and organized with similar elements, or in logical groupings. Of course, this is just my opinion, as some people are masters of dealing with their own chaos.
We have hundreds of designers, drafters managing sketches under the solid features...
And we use sketches for many things, from X section to solid feature profile, we use output features also, and sketches for many other purposes... We all manage our file/geometry without sketch problem...
We do not put all sketches in one(or several) geometrical set to manage them but to filter them when drawing X-section.
You might call that Chaos... but no big problem for several years...
My thanks!
