Pro Mechanism
Pro Mechanism
I'm using WF 2.0 and when I assembled part using "pin" connectiont they always failed but I can hit OK and move it around. Is this Normal. It says "failure to assemble based on current connection definition". This used to work in 2001 and I have no idea how to make it to work again.
Any ideas?
Any ideas?
RE: Pro Mechanism
Try to make sure that the assembly references for both the axis and the plane come from the same part or body.
