Converting Feet Gas Column
I recieved an old document with pressure listed in "Feet Gas Column". Does anyone know what this is or how to convert it to inches water column?
RE: Converting Feet Gas Column
The equation used most often in Oil & Gas for figuring bottom-hole pressure with a gas column is:
P(bottom) = P(top)* exp((0.01875*SG*depth)/T/Z)
With:
Pressure in psia
Temperature in Rankine
SG relative to air
depth is column height in feet
[Note: since atmospheric pressure is a significant number of feet of gas column it is important to get it right at the top. Predicting gauge pressure at the bottom is a really tricky thing since on well-magnitude problems your elevation can be thousands of ft lower than surface pressure, for a monometer problem this shouldn't be a problem]
The result is in psia and can be converted to ft of pure water at 60F by dividing the answer by 0.433 psi/ft.
This equation tracks well on wellbore-magnitude problems (i.e. hundreds of feet), I'm not sure how well it would work on monometer-magnitude problems.
David Simpson, PE
MuleShoe Engineering
www.muleshoe-eng.com
The harder I work, the luckier I seem
BigInch
-born in the trenches.
http://virtualpipeline.spaces.msn.com
David
BigInch
