Testing CO2 Fire Fighting Protection
Hi there!
I need to test the CO2 Fire Fighting Generator Protection, but I'm worry about some effects in the generator itself (stator-rotor insulation, air coolers).
Do anybody have some experiencie in this kind of issue?
Thanks in advance!
Thanks in advance!
RE: Testing CO2 Fire Fighting Protection
Yes, you right, it is a new system, we have afraid of contamination and corrosion in Generator parts.
We have a water condensation in air cooleres of the generator, I think that CO2 could react with water in acid decreasing the life of copper tubes. Another hand I would like to test the system when the generator is running with low power production to check the Trip, other thing is temperature of coils is as hot as 90°C against the CO2 wich will be cold, some thermical shock could occurred. Another design issue is that we have only one CO2 rack for 3 Generators.
Thanks in advance
