Rotating imbalance from faulty rotor bar joints
I have recently had some rotors tested(with a core loss tester) and the results showed some high resistance joints between the rotor bars and the short circuit ring(these are brazed joints). I know that these high resistance joints will cause vibration issues, high current draw, and heating issues. I would like to calculate(or estimate)the amount of force or imbalance that would occur from a high resistance joint in a rotor circuit. Any help would be appreciated.
RE: Rotating imbalance from faulty rotor bar joints
Force = S·W·A·G
Where Force is in units of lbf
JRaef.com
"Engineers like to solve problems. If there are no problems handily available, they will create their own problems."
Scott Adams For the best use of Eng-Tips, please click here -> FAQ731-376
W = Weight of rotor; A = cross sectional area; G = acceleration of gravity (required for English units).
Actually I wasn't trying to be a wise guy in response to the original question. I suspect any attempt at calculating this would be very involved, require many gross assumptions, and be very inaccurate.
Unfortunately, the formula then also needs a term (or terms) that can cancel the extra m*A3/s from the results.
