color change after heating the metal?
I guess this would be a simple question for a metallurgical engineer,
We have a sprocket made of 4140 HTSR steel that gets heated to be pressed onto a shaft. The oven is set to a 180-190 deg. C. 2 of the sprockets were left in the oven for a longer time (maybe 1-2 hr) and the color changed to a dark yellow.
Geometry hasn't been effected. Now I have to determine if it's OK to use these sprockets, but I can't say if there were any changes to metal itself.
Thanks.
Thanks.
RE: color change after heating the metal?
I think your're fine.
rp
We operate 4140 parts at 283C for days on days with no problems.
