Assembly Pattern
Assembly Pattern
Assembly Pattern
I am beginning to put a deck together.  It is becoming rather tedious to constrain each individual floor board.  How can I create a pattern to insert several of the floor boards at a time?  Thanks.
RE: Assembly Pattern
Place the first board and constrain it, then use the "pattern component" feature. It is the 4th tool down in your assembly panel. When you open the pattern tool select the second tab (rectangular).
