assembly reactions
assembly reactions
assembly reactions
Hello.
Can someone tell me, how to delte reaction in assembly?
I have 2 parts and I added a reaction to parameter on first part for parameter change on second part if I changed parameter on the first part.
On root assembly I see:
Relations\Reaction.1\Activity   True
I can't delete it because I get this message:
you can delete only the new parameters that you have added to the part. The parameters created for each feature can be delete only by deleting the feautre itself.
So what do I need to do, to remove this "reaction"?
Btw, on root of the tree, I don't see "parameters" or "relations" icon. And I can't find "reaction.1" anywhere else, but clicking to f(x) button.
RE: assembly reactions
Set tools - options - infrastructure - part infrastructure - relations.  You should be able to see the rule now in Part1.
Derek
