software for Hoefer data logger and denistometer?
I understand that Hoefer does not make nor support the data logger interface for its densitometer. Can someone provide me for the software to connect and use this on the PC?
RE: software for Hoefer data logger and denistometer?
Do you have the manual and schematics of the densitometer?
What is the software supposed to do?
Plesae read FAQ240-1032
My WEB: <http://geocities.com/nbucska/>
Actually the densitometer is a device for scanning gels and films and outputs the data to a strip chart recorder which makes graphs out of it. The data is a voltage data from 0 to 1 volt. Now Hoefer also makes a data logger interface whcih can be connected to the densitometer instead of the chart recorder and the data logger is then connected to the computer through a serial port. The software is necessary to collate and interpret this data and then caluclate area under curves and so on.
