H2S Solubility in Brine
Looking for information on the solubility of H2S in concentrated brines (30000 to 40000 TDS or so) or even seawater at temperatures in the range of 100 to 200 deg F and atmospheric pressure.  Need to understand if saturation limit is depressed significantly in brine solution compared to pure water.
RE: H2S Solubility in Brine
I would say not much. H2SO4 2.4% only slightly lowers the H2S solubility. I do not have any dat for brines, but I do not expect a huge impact.
If you can follow the maths, the following might be of some use:
Oil & Gas Science And Technology Rev IFP, Vol 60, 2005, No 2, pp339-355
Steve Jones
http://www.pdo.co.om/pdo/
LnC= A1+A2(100/T)+A3Ln(T/100)+A4(T/100)+{S[B1+B2(T/100)+B3(T/100)^2]}
C: Solubility of H2S in water @1 atm in mol/kg
Ai and Bi: factors
T: Temperature in Kelvin
S: TDS in gr/L (eg. 30 or 40)
(Weiss 1971)
A1:-41.0563
A2:+66.4005
A3:+15.1060
A4:0
B1surprised.060583
B2:+0.0379753
B3surprised.0060234
(Ref: The physical Chemistry of Natural Waters Frank J. Millero Eq. 5.34)
I can't find any temperature range for that correlation.
Hope this help
