setting-up colours based on different sets
I just want to change up the set-up of colours based on different Sets . I looked around 20m in the documentations on line but without finding how to do so.
Sorry from ABAQUS experts if the question is simple
RE: setting-up colours based on different sets
Hi
In Viewer there is a drop-down box on the toolbar at the right hand end.  You can use the preset selections in here to colour code the model by elemene set, part instance, materials, section etc.
If you want to alter the defaults, go into the "Color Code Dialog" (palette shaped icon next to the drop-down).
Martin
Thank you Martin
This only allows you to colour the sets of your model in the visualization module (after the solution has been done :after you run the Job). What if one wants to colour each set in early stages in the Assembly ,Mesh, Load, modulus..)
Thanks for the time you are taking to answer me
It's all there in the current version (V6.6) - color code by set/surface/load/bc/interaction/etc etc.
