Need 36" wide 120 BHP 15# steam boiler
I am looking for a manufacturer that makes a 120 BHP low pressure steam boiler that will fit through a 36" wide door.  Height and length are not an issue, but width is.  I actually need a total of around 480 HP and was hoping to install 4 boilers.  That number can possibly be increased or reduced as long as the total is the same.  Higher efficiency is better.  Natural gas for fuel.  I found a manufacturer called L.E.S., but I don't know much about them.  I would like to have some other options.
RE: Need 36" wide 120 BHP 15# steam boiler
Sounds like you may want a watertube boiler brought in piece meal and assembled on site.
If it is for heating only look up sectional cast iron boilers.
