Opening Solidworks files?
4
How do I keep the dialogue box set to a default size. For
example when I click on File -> Open  a dialogue box appears saying Look in, File Name, and etc. In the lower right hand corner there are three lines at a fourty-five degree angle and this allows you change the dialogue box size.
My question is how do I let SW leave the size I want everytime I get into SW ?
Printed Circuit Board Designer
Stangs rule!
RE: Opening Solidworks files?
I don't think there is away... unless you find a reg hack to control its size, otherwise I don't see away in SW to control the open dialoge box.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
I believe the answer you seek is here:  thread559-150005
Thanks guy !
Stangs rule!
You will not need it in SW07 because it remembers the open dialog box setting such as size and view preferences (detail or thumbnail), and order by "date modified", etc.
SW07 SP1.0
Flores
