Echoing Ansys GUI commands?
Hi all.
I'm in the process of learning to write ansys .inp-scripts (I'm using Ansys 9.0).
Is there a way to echo the commands given in the GUI to the output window (or somewhere else where they could be found)?
An example may clarify my problem:
I know that to plot the elements one uses a GUI command Plot->Elements. I would like to know what is the exact command to achieve this action by observing the output window (or some other log file) - now I see something like
"produce element plot in dsys = 0", and nothing about "eplot" which I know to be right command in this case.
Thanks in advance for your answers. A solution to the problem would accelerate my learning process a lot!
RE: Echoing Ansys GUI commands?
File > write DB log file
Hope thats your question.
Jalil
-Brian
