Alloy 20 Impacts
Alloy 20 Impacts
Alloy 20 Impacts
Based on the fact that this material is exempt to -325F in Sec VIII UNF, I'm thinking 15/12 at -160F should not be a problem.  Any thoughts?
RE: Alloy 20 Impacts
weldtek;
Agreed, probably 100 ft-lbs at -160 deg F for this alloy in an annealed condition.
Considering that you should have about 200 ft-lb CVN at RT, and that I have seen cryo tensiles with nearly 50% elongation I would suspect that you will see good low temp impacts.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
Thanks for the input. Our customer has asked for impacts even though its exempt and, for some reason our material vendor is taking the 'for information only' stance.
