Measuring TIFF file
Measuring TIFF file
Measuring TIFF file
I have a TIFF file and Need to measure some dimensions on it. I would like to knew If there is any software to check dimensions on TIFF Image file.
Thanks N Advance,
GSK
RE: Measuring TIFF file
Do you mean to measure various parts on a drawing with a scale?  Usually I insert the record drawings that have been scanned to TIFF into Autocadd, then scale it up to 1:1 using the identified drawing scale.  It is not very accurate and depends on the resolution of the TIFF.
You can also use a program like Paint Shop Pro and measure pixels.
