How to create an annotation view parallel to screen?
Is there anyway to create an annotation plane parallel to screen?
RE: How to create an annotation view parallel to screen?
This may or maynot suit your application
Jack,
I haven“t found this option in Assembly Workbench, where I can find it?
sparck
The function is available in Part Design, but it's not included in any toolbar. Sounds like it's the same in the Assembly Design workbench.
So, click in the Power Input field (lower-right corner of screen) and key-in: "c:text parallel to screen" (no quotes)
If it does what you want, you can add the command to one of your Assembly Design toolbars
Text parallell to screen can be zoomed if zoomable(R16) is toggled on (properties/display tab)
