Brick wall on Steel beam
hi all
 is it a common practise to use a steel beam for carrying brick walls ? if so what provisions should i follow?
RE: Brick wall on Steel beam
Yes, structural steel lintels are common. For general information, see the Brick Industry Association, Technical Note 31B "Structural Steel Lintels". Here is link to the Tech Note page http://www.bia.org/html/frmset_thnt.htm
Also check the appropriate building code.
www.SlideRuleEra.net idea
Limit deflection to L/600 or 0.3 inches.
