Space Mouse Setup
Space Mouse Setup
I would like to set up my space mouse so the plus and minus commands change the sheet up and down one sheet. So for example if I was one sheet.1 and I hit the plus button on space mouse I would go to sheet.2
I ensure that my sheet are always in order and they are always named too the sheet.1, sheet.2 sheet.3 style of naming. How do I set up my space mose to do this?
RE: Space Mouse Setup
If there is not shortcut for NextSheet, then you will have do write a script and make the shortcut to your script.
Is there s spot in the help files?
