GEROTOR pump, dry sump engine pressure problem
We have built a race engine. It's a 2jz-gte supra 3 liters engine and we have applied a dry sump kit.
We are actually using a peterson gerotor 3 stages pump rated at 18/20gpm (at how many rpms?)
We have a 5 gal tank in the trunk and a -16an line going to the pump and -12an line pumping oil inside the engine.
2 scavenging lines keeps the tank always at at least 2/3 of the level.
Here is the problem:
hot oil, idle 1600rpms, 28psi of oil pressure.
everything is ok so far.
Increasing the engine rpms we see an incease in flow and pressure. We are actually using evne a flow meter gauge.
Everything is ok up to about 6k rpms engine speed where we have about 117psi of pressure and 16gpm of oil flow.
At this point we have problems:
keeping the engine STEADY at 6k rpms we start to see a drop of oil pressure BUT NOT a drop in flow and this could be caused MAYBE by the increasing of oil temperature and loss of oil viscosity.
If we increase the engine rpms we have an even more accentuated loss of oil pressure but still absolutely no loss of oil flow.
The actual pump ratio is 52% so cavitation due to excessive pump speed should be possible. These pumps are rated at well more then 5k pump rpms. At 6k engine rpms we are at about 3k pump rpms.
Cavitation due to small inlet line should not be the case as well. We are using the -16an line as per pump instructions. The oil line have no tight bents.
The actual gerotor is 1.1 inches wide. The stock oil pump is 0.8inches BUT spinning at 100% of engine speed.
The external of the actual pump is about 2.75inches. While the stock pump was 4.3inches.
Could be the actual pump undersized?
Is there any way to calculate the oil volume that the stock pump was flowing based on the rpms/gerotor size?
Any help would me really appreciated.
RE: GEROTOR pump, dry sump engine pressure problem
Do you have an oil cooler?
Where is the relief valve? Does it flow enough? Is it working properly?
We use an oil cooler yes and it is way over rated with 2 inlets and 2 outlets -12an each of them.
Engine oil pump is more likely to have loss of pressure with temperature due to leakage and turbulence as well as increased bearing clearances.
We have set the relief valve point at 117psi.
The problem is that the engine have a red line of 10500rpms and at 7krpm we alreayd have an huge oil pressure drop. At 7k rpms teh oil pressure is already at 70psi and lowering quickly. At 8krpms we read 58psi of oil pressure that is WAY too low.
The stock oil pump was able to keep a linear oil presusre up to the red line.
Maybe we need to go to 1:1 speed ratio?
Before you risk engine damage, set up a bench test. Drive the original oil pump and the gerotor pump in turn with an electric motor, pumping oil to and from a bucket. Measure the flow of each, and compute the flow per pump revolution.
Mike Halloran
Pembroke Pines, FL, USA
What kind of oil are you using? I recall in another forum, a similar problem, the problem went away when they changed to a non detergent synthetic oil. Apparently a lot of modern synthetic oils, especially the ones that advertise a long duration between oil changes have too much detergent in them.
When the oil is being thrashed about at high speed(read high RPM) the detergent turns into froth which is why the oil presure goes down.
If you have a breather valve in either the head or the block try and connect a clear plastic hose to the breather. Then run the engine. If the clear hose fills with froth you have a problem. Try running non detergent oil and see if that helps.
Bye for now
Make sure oil tank has scavenge lines arranged so the returned oil is striking the inside of the curve of a curved surface. It should strike at a tangent well above the oil level and above a screen that will "filter out: air bubbles.
Some if not all oils contain anti foaming agents. An oil with a good anti foam package should help.
I am using the MOTUL 300V competition oil.Not sure about the level of detergent inside it.
I have an hole in the head where originally were palced the hose for the oil vapours. I will use that place to do the test. But I don't think that even if the oil is foaming it will be so bad that it will arrive up there and fill the hose.
Patprimmer sincerely I'm not so sure about areation. I really don' tthink that our problem is that.
I use a moroso tank that should perform very well and divide oil and air very efficently...
I still think about a volume problem compared to the stock pump.
A drop off at high speed is normally the level in the sump dropping and uncovering the pickup (unlikely with a half decent dry sump) or the pickup sucking up the bottom of the sump (impossible on a dry sump unless the sump fabricator/designer was a complete idiot).
The other possibility is that the bearing and journal acts as an eccentric pump and centrifugal force pulls oil from the main gallery. These could combine to decrease the rate of pressure build up with speed. Porsche used very small oil holes in their cranks many years ago to reduce that tendency.
Is there any sign of the bearings being overheated. 117 psi at 6000 rpm sounds like plenty of pressure to me, and as the flow is good, presuming the oil quality (read contains little or no air) I don't see a problem.
The only function of pressure is to induce sufficient flow to ALL points required, hence the small crank drilling so as to leave sufficient pressure in the main gallery to stop the big ends robbing to much from the mains. The only anomaly I see with this explanation is the pressure should taper off rather than hit a wall or actually decrease.
A very simple test would be to try another oil.
We have even more flow ( 20gpm ) but even less oil pressure (about 60psi of oil pressure...)
So the flow increases but the oil pressure go down and down...
At this point is it a problem of a too small oil pump?
Additionally, in my opinion, the dry sump pressure section is too large or your relief valve is adjusted too high. A good correlation is 10 psi per 1000 rpm. Also, I am assuming that the relieved oil feeds back to the inlet of the pressure stage.
Another possible scenario is a restricted or collapsing oil suction hose to the pump inlet.
Cheers
Greg Locock
what do you mean? can you explain?
Cheers
Greg Locock
I wonder if the problem is that this engine really wants more oil then usual.... the crank have been modified by us: it was a striaght shoot crank. We have added an hole on the rods journals going from one side to the other of the journals and we have even made the mains full groove from half groove...I wonder if this is the reason why the oil pump with a ratio of 50/60% is not sufficent...
Pressure is a result of resistance to flow.
To change the pressure you must change the resistance.
The things that effect resistance if the pump is turning (say by being disconnected from the engine drive and being connected via an outside source) are static bearing clearances, oil viscosity and oil passage sizes.
Once the engine is turning, centrifugal force is applied to oil in the crank passages and the big ends act as an eccentric oil pump. This pumping action is dependant on the effective clearance (which changes with localised temperature changes while running) and effective film thickness on the loaded and unloaded side of the journal.
The pressure at any two points in the system will vary depending on supply to the system and restrictions before and after that point.
Most measure their oil pressure between the pump and the main gallery, but the critical points are the individual entrance points to the journals and the differences between them.
Splash feed gives enough lubrication so long as heat is not an issue. Splash feed depends entirely on film strength and has no hydrostatic component. I believe (I read it somewhere) that oil film strength is much greater than hydrostatic effect as seen at a bearing journal in an automotive engine.
A modern engine runs at high enough loads and speed to create enough heat to melt a splash fed bearing in seconds.
Pressure simply promotes flow. Flow cools bearings. Hot bearings heat the oil and reduce the film strength and thickness on the loaded side. Hot journals expand and reduce clearance as the caps cool more than the crank. Tighter clearance then reduces oil flow, which reduces cooling etc etc.
Do you have any signs of overheating at the bearings. If not, what is the problem other than numbers on a gauge that is not measuring at the most important places and is only measuring a parameter that is separated from the real parameter by several degrees of separation.
Just a thought, can oil pressure gauge pickup or sensor location be effected by venturi effect.
Fabiom, go back and read your engineering textbook chapter about hydrodynamic lubrication and you'll understand where your oil pressure went.
Mike Halloran
this forum is an amazing place! :)
Now I am pretty sure that the problem resides in the full grooved mains.
I have been searching about this topic on google but I have found almost nothing... No real comparison/benefits/pro/cons between full, 3/4 and half groove...
Beisdes we are NOT using full groove bearings BUT we modified teh block itself: we made a 360 degrees groove all around the main: on teh block and on the cap. This way we didn' tmodified the breaing to keep the original strenght of the bearing itself but we allow a constant oiling to the bearing due to the 360degrees groove that we made.
Any suggestion and idea about this?
Could there is some king of flow restriction after the pump, like the filter sandwich/adapter? Try installing that pressure sensor right after the pump and see what it reads there. I am betting it will read 117 psi all the way to 10K rpm.
I am also doing a dry sump project on a similar engine. My pump is rated 12 gpm at 2500 RPM. It is geared down 60%.
This is how I was sizing my dry sump pump:
ht
Actually, this does not show the real procedure when I had both of the pumps on the electric drill at the same time. They filled two large trash cans pretty quickly. The dry sump pump filled up its can with about 2.1 times more water. After multiplying 2.1 by the 60% gear ratio that is 26% more oil flow than the stock pump, so I am pretty happy.
I have not ran the actual engine yet. Hopefully later this month. Wish me luck! And please report your findings. Thanks.
It really seems like the pump is not flowing enough oil for this eninge. More exactly. For all the mods we made to this engine.
Ok here are our thoughts:
we made some experiemnts.
1) we brought the pumps rpms higher. We used a ratio of 1:1. We wanted to see and log with teh telemetry what the CAVITATION looks and sound like. We reached it easily at 6k engien rpms. Well teh way you read cavitation on the telemetry and the sound is completely different from what we had before.
2) we measure the oil pressure right after the oil pump. Using the 55% ratio with no cavitation. Brought slowly the pump at the rpms level were we had teh problem and logged. There is a costant drop in oil pressure with no cavitation at all that is pretty much accentuated after 6500rpms.
After reading the article thet GregLocock suggested me ( http
Seems like in that test at about 6500rpms there is a big difference in oil flow with HALF GROOVE vs FULL GROVE.
A drop in flow means that the oil is having trouble to pass thru the oil holes. This even means that the pressure will most likely go higher.
That is where we start to have problem. it could be a coincindence but I am not sure.
Actually there could be many reasons why this supra block wants more oil
We moved from a stock cross drilled crank to a striaght shoot crank. This already helps teh flow at high rpms due to the resons that all of us knows (centrifugal force with cross drilled makes the oil flow problematic at high rpms)
Beisdes we modded it: a normal striagh shoot crankhave have one hole going from the main journal to the rod journal. We added a pass thru hole to the rods journals. NOT SURE how much this could help as probably the centrifugal force wont allow much oil to pass thru that hole and go to the opposite side of the bearing. But it could help a bit.
Plus we added a FULL GROOVE on the MAIN caps and the block. this should help to feed the rods journals all the time. (we made the full groove on the main caps and the block. The main bearings are grooved for 1/4 plus they have holes all around 360 degrees. We didn't wanted to mod the bearings to avoid problems with weakness.)
All of these mods could be teh reson why this engine wants more oil.
Right now I have in front of me a new oil pump with dual pressure stage. Rated at 25gpm.
We will isntall it this week and I will let you know.
Any help and thought even about the full grooves would be VERY VERY appreciated
fabio
