How to use customized toolbar item for a block insertion?
Hi,friends,
   I'm using AutoCAD VBA to develop a module for drawing hydraulic circuit, and plan to make the block for every standard parts, such as pumps, valve. But now I get trouble on how to use the customized toolbar item to command the insertion of corresponding block? Thanks.
RE: How to use customized toolbar item for a block insertion?
here's my secret insert routine...enjoy
Public Function InsertBlkRef(ByVal sBlkName As String, _
Optional ByVal bExplode As Boolean = True, _
Optional ByVal iSpace As Integer = 0, _
Optional ByVal dScale As Double = 1#, _
Optional ByVal vInsPt As Variant, _
Optional ByVal dRot As Double = 0#, _
Optional ByVal bLastObj As Boolean = False) As AcadBlockReference
'InsertBlkRef:  Defaults are:
'               EXPLODED
'               MODELSPACE
'               1:1 SCALE
'               0,0 INSERT POINT
'               0 ROTATION
'               True RETURN LAST EXPLODED ITEM (use after explode of block
'                   which reveals another block)
'Arguments:     sBlkName = path and/or filename (i.e. "someblock.dwg")
'               bExplode = insert exploded TRUE or not explode FALSE
'               iSpace(OPT) = 0 for paperspace and 1 (default) is modelspace
'               dScale(OPT) = scale, the same for X and Y
'               vInsPt(OPT) = insertion point, zero-zero if none given
'               dRot(OPT) = rotation in degrees (converted to radians
'                               within function), defaults to zero if not given
'Returns:       Block reference (if it is the only item in the block)
Dim acBlkRef As AcadBlockReference
Dim dInsPt(0 To 2) As Double
Dim acBlkEnts
On Error GoTo ErrHandler
'Set insertion point. Set to 0,0 if none given
If IsMissing(vInsPt) Then
    dInsPt(0) = 0#: dInsPt(1) = 0#: dInsPt(2) = 0#
Else
    dInsPt(0) = vInsPt(0)
    dInsPt(1) = vInsPt(1)
    dInsPt(2) = vInsPt(2)
End If
dRot = DegreesToRadians(dRot)
'Check if need to add .dwg for pathed files
If InStr(sBlkName, "\") And Not LCase(Right$(sBlkName, 4)) = ".dwg" Then
    sBlkName = sBlkName & ".dwg"
End If
'Set space to insert into. Then insert drawing
If iSpace = 1 Then
    Set acBlkRef = ThisDrawing.PaperSpace.InsertBlock(dInsPt, _
    sBlkName, dScale, dScale, dScale, dRot)
Else
    Set acBlkRef = ThisDrawing.ModelSpace.InsertBlock(dInsPt, _
End If
'Make sure block is inserted and explode if required
If Not acBlkRef Is Nothing Then
    If bExplode Then
        acBlkEnts = acBlkRef.Explode
        acBlkRef.Delete 'Gets rid of original copy, leaves exploded one
        If bLastObj Then
            Set InsertBlkRef = EntLast 'last modelspace entity
        End If
        Set acBlkRef = Nothing
    Else
        Set InsertBlkRef = acBlkRef
    End If
End If
ExitHere:
    Exit Function
ErrHandler:
    Debug.Print vbObjectError + 514, "PP_ACAD Error", _
    "Function 'InsertBlkRef' Failed"
    Err.Clear
End Function
"Everybody is ignorant, only on different subjects." — Will Rogers
thanks borgunit, I'm trying!
Is there a way to insert a single specified block from with in a drawing containing multiple blocks? (other then the design center!)?
Just insert and specify the block name. AutoCAD works with names.
