Additional apps (edrawings) installed with admin image
I have created and installed from an admin image (sw2007sp0.0) and now I'm attempting to create my "additional apps.bat" file. I've referenced thread559-123403 but I wasn't able to unzip the files from the *.exe file using winzip. I had the evaluation version, do I need pro?
Craig Sink
Mechanical Engineer
Force Design, Inc.
RE: Additional apps (edrawings) installed with admin image
There are a couple of differences with the admin image for '07 versus previous years and they weren't well documented.
Jeff Mirisola, CSWP
CAD Administrator
SW '07 SP1.0, Dell M90, Intel 2 Duo Core, 2MB RAM, nVidia 2500M
Craig Sink
Mechanical Engineer
Force Design, Inc.
Msiexec /I"\\server\Updates\Solidworks\SW 07\Cosmos\i386_COSMOSWorks_English.msi" INSTALLDIR="C:\Program Files\SolidWorks" /qb.
Msiexec /I"\\server\Updates\Solidworks\SW 07\Add-ins\swexplorer\SolidWorks Explorer.msi" EXPLORERORPDM=1 INSTALLDIR="C:\Program Files\SolidWorks" ADDLOCAL=Client /qb.
Msiexec /I"\\server\Updates\Solidworks\SW 07\Add-ins\DWGeditor\DWGeditor.msi" INSTALLDIR="C:\Program Files\SolidWorks" /qb.
Msiexec /I"\\server\Updates\Solidworks\SW 07\Add-ins\eDrawings\eDrawings.msi" INSTALLDIR="C:\Program Files\SolidWorks" /qb.
I don't know if this will help you out or not...
Jeff Mirisola, CSWP
CAD Administrator
Here it is:
rem **Install dwgEditor
s:
"S:\SOFTWARE\SOLIDWORKS\SWADMIN2007\SolidWorks 2007 SP 1.1_DWGEditor\DWGeditor.msi" INSTALLDIR="C:\Program Files\DWGeditor" /qb
REM **Install eDrawings
"S:\SOFTWARE\SOLIDWORKS\SWADMIN2007\SolidWorks 2007 SP 1.1_EDRAWINGS\eDrawings.msi" INSTALLDIR="C:\Program Files\SOLIDWORKS\common files\eDrawings" LOGPERFORMANCE=0 ADDLOCAL=All /qb
REM **Install SolidWorks Explorer
"S:\SOFTWARE\SOLIDWORKS\SWADMIN2007\SolidWorks 2007 SP 1.1_explorer\SolidWorks Explorer.msi" INSTALLDIR="C:\Program Files\SOLIDWORKS\SWExplorer" /qb
Craig Sink
Mechanical Engineer
Force Design, Inc.
Hmmmm...That's basically like what I started with. I got an error that said something like "this file is not a recognizable...." I forget the rest, but, basically it didn't work. I could dble-click on it and also see my previous post, but the correct syntax didn't work. Odd.
I'll keep looking into it.
Craig Sink
Mechanical Engineer
Force Design, Inc.
I copied your .bat file and changed the paths to match mine..and it worked! I'm not sure what I was doing wrong...but the main thing is to know what works. I did wonder if I didn't have a backslash "\" after the msiexec rather than a "/", but I don't know.
Thanks for the help,
Craig Sink
Mechanical Engineer
Force Design, Inc.
I'm glad I could help.
Remember, if your clients install via the html tag that the admin image creates, they should be updated automatically after you apply a service pack to the admin image.
Jeff Mirisola, CSWP
CAD Administrator
