Non-lubricated Large Bushing in Mining - Material and Design
I am looking for a way to improve our pin connections used in large mining equipment. The pins diameters range from 3-10" with bearing pressure reaching 7500 psi. The velocities are very low with small osciallation. And of course the bushing/pin will see dirt and impact loads, and no p/m will ever be done (hence non-lubricated). Traditionally, manganese steel bushing with 4340 pins have been used with poor results. Is there better choice of materials? I also could use a good sources of design information (rule of thumb for hardness difference, design methodology, ect).
Ken
Ken
RE: Non-lubricated Large Bushing in Mining - Material and Design
Here is the one that I've always used. I don't know about the available diameters. They do go to 3". I would give them a call to see what is available.
http://w
What do Caterpillar and Komatsu do?
Boosting hardness can help some with pure abrasion, but running similar metals unlubricated can bring on BIG galling problems.
I have to think incorporating less-similar materials, , with highly finished round holes and shafts, EP dry lube at assembly, and rudimentary sealing (even at the expense of projected bearing area) would reap huge benefits.
help like the aisi 8660 for the pins
would be a better choice. They are coating
a lot of shaper cutting tools to make them last
longer. I wonder if that would help in
this case.
