Xref path change
Xref path change
Xref path change
I received a copy of a project on CD with over 500 drawings along with the Xref files for use in construction, however, when I open the drawings on my computer I only see a partial of the drawing.  I can manually edit each drawing Xref path, so that it finds the Xref drawing on the CD in oder to get the full draiwng, but this is very time consuming.  1.  Is there a way to make a global change on the copy I have to correct this? or 2.  Can the person making the copy put all the files in one directory with the Xrefs linked to the same directory or something?
RE: Xref path change
I use eTransmit. It keeps all xref;s together.
I don't know of an easier way to fix them. I do it manually.
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-06)
Does your AutoCAD have the "Reference Manager"? In Start>>Programs>>Autodesk>>??Your Version??
"Everybody is ignorant, only on different subjects." — Will Rogers
I am using Autocad LT 2002.  Where would the reference manager be?
