Polymer @ 0.5% TSS Solution?
Help,
I am trying to make sense of calculations for a potable water treatment plant. The following are particulars listed for the plant:
Raw water flow rate = 1,600,000 gpd
Polymer dosing rate = 2 mg/l
Polymer solution = 0.5% TSS solution.
Polymer required = 26.7 lb/day
Without knowing the particulars of the polymer, can anyone tell me how to calculate the flow rate (in gpd) of the the polymer solution?
Thanks for the help.
RE: Polymer @ 0.5% TSS Solution?
Thus, need 1/0.5% = 200 times as much of the mixture by wt. So,
26.7 lbs/day x 200 = 5340 lbs/day.
Taking the mixture's density as 8.34 lb/gal,
need 5340/8.34 = 640 GPD of the mixture (0.4446 gpm).
DocMax (Chemical)
18 Sep 06 15:54
hi madhusmile
first you will know what is the dilution of polymer.
Polymers are so viscous so it's necessary to make a diluition.
For example if the polymer solution after dilution is 0.5% the math is:
1,600,000 gpd = 252.36 m3/h 2 ppm = 2 g/m3
252.36 m3/h X 2 g/m3 = 504.72 g/h
504.72/0.005 = 100944 g/h = 100.9 kg/h
If the density of solution is 1000 kg/m3:
100.9 kg/h / 1000 kg/m3 = 0.1009 m3/h
the dosing pump will be 0.1009 m3/h = 100.9 l/h = 0.444 gpm or 639.998 gallon/day [US]
2 mg/l / 120 = .0166 lbs/1000 gal
.0166 lbs/1000 gal X 1,600,000 gpd = 26.6 lbs/day polymer
26.6 lbs/day polymer / 0.005 solution strength = 5,333 lbs/day solution
5,333 lbs/day solution / 8.34 lbs/ gal = 639.48 gal/day polymer
I tried searchig for the topic before posting, but could not find it...for this particular topic, how should I have searched for it?
Thanks!
http://www
I tried searching for it and could not get it to come up. Unfortunately it has misspelled words that won't search.
