Question on a Control Valve Selection Article
For those who have a few minutes and don't mind reading an article, I have a question that I can't get past.  The article is on selecting control valves for variable flow hydronic systems.  I have sent an email to the author and hope to hear back.  In case I don't, I would appriciate an explaination from someone.  The article can be found here:
http://www.kele.com/archive/solutions/SelValvesHydroSys.pdf
My specific questions are as follows:
On the bottom left of page 2, the Cv of the branch is calculated to be 27.8 for a flow of 100 GPM and a branch DP of 30’.  But this is for the entire branch, so the actual control valve will have a Cv of 39.2 (100/(15/2.31)^1/2), correct?
If that’s true, then I am confused by the next statement that a 95’ drop across the valve will result in a max flow of 191 gpm.  With a Cv of 39.2 and a DP of 95’, flow should be 251 GPM.
What am I missing here?
RE: Question on a Control Valve Selection Article
Using Cv = 27.8 and 95 ft head drop across the valve PLUS 15 ft drop head in the branch,
Q = 27.8 * ((95+15)/2.31)^0.5
Q = 27.8 * 47.6^0.5
Q = 27.8 * 6.90 = 191 gpm
BigInchworm-born in the trenches.
http://virtualpipeline.spaces.msn.com
