Converting PPM to SCCM
I need to figure out how to convert a concentration of a gas in PPM to a flow rate in SCCM. I know the gas, the pressure and am using a sniffer probe that reads in PPM.
Thanks!
Thanks!
RE: Converting PPM to SCCM
You cannot convert concentration into flow rate without knowing the bulk flow rate and nature of the carrier gas at the prevailing flow pressure/temperature conditions.
Then don't forget to clearly establish what are the standard conditions of pressure and temperature the sniffer probe is using.
