changing a spline into line/arc segments
NX3
sketch
is it possable to go back into a sketch and change a projected edge, from a single spline to orignal lines.
then add constraints to lines/arcs.
Reason: splines can not be dimensioned in drafting.
Robert
sketch
Robert
RE: changing a spline into line/arc segments
I think you can select what kind of curve is created only at the time of projection. I know from an email I saw on improvements to projected curves in NX3 the functionality is a lot better. I think you now have the ability to offset a curve while projecting to a sketch with out have to extract the original curve first.
Michael
