Control Wall w/orifice, advice
I have two very large pre-cast storm structures(round), that have a control wall inside of them. These walls got overlooked at bid time, and I am now responsible for figuring out the easiest, but most cost effective way to fabricate these in the field. Both of these structures are at the outlet ends of large underground detention systems, and the walls are required to slow the rate of flow down. I am only aware of two choices, steel or concrete, to make these out of. The wall that goes in thelargest of the two structures is detailed as being seven feet tall with three orifices in it. I am debating if the steel plate would be easier than trying to pour in place concrete. Not sure if any of you have run into anything like this, but if so, some advice would be appreciated.
RE: Control Wall w/orifice, advice
Swimming pools, movie stars....
