Unlubricated, cryogenic bearing
We've been having problems with some bearings in cryogenic hydrogen service ( -420 F). The bearing is in the liquid hydrogen flow stream and can not be lubricated.
Size: 20 mm ID, 47 mm OD, 14 mm wide.
Style: Roller
Speed: 12,000 RPM
No lubricant.
Operating temp: -420 F
Load: Indeterminate, supports rotating pump shaft. No large radial loads. Weight supported may be aprox. 10 pounds.
I've gotten some quotes back on a replacement bearing.
1'st quote:
Ceramic rollers, corrosion resistant high nitrogen steel, Teflon impregnated PEEK cage, C5 clearance.
2'nd quote:
Corrosion resistant, high nitrogen steel rings and rollers, glass filled Teflon cage with molybdenum disulfide added, C5 clearance.
Both bearings have the same load rating which is on the order of 5000 pounds.
Any thoughts on what might work best for this application would be appreciated.
Style: Roller
Speed: 12,000 RPM
No lubricant.
1'st quote:
2'nd quote:
RE: Unlubricated, cryogenic bearing
the whole process may add $50 to the standard bearing, so it would be an inexpensive test
Russell Giuliano
What minimum temperature has this lubricant been tested at?
Who makes your bearing parts? (races, balls, etc...)
Do you have any experience with similar (cryogenic) applications?
Russell Giuliano
The lubrication in such application is critical specifically due to the fact that the cryogenic fluid in the contact zone (ball raceway contact) vaporizes forming bubbles (Some cavitations effects with peculiar properties). NASA has several papers on the subject (specifically the bearings for turbo pumps, their failures and method to prevent them) that can be of help to you.
Sorry if I made some error in assuming you worked for Unique Technologies. I guess because you've signed your name with that heading, such as in this thread that I'm confused: http://www.eng-tips.com/viewthread.cfm?qid=116417
And because there's a Russ in customer service at UT. Oh well, my appologies.
Hi Volpe, The bearings I've been quoted haven't been tested in the shuttle, though I've heard about the ones you're refering to. Can you provide a link to the papers? I'd be interested in reading more about them.
Russell Giuliano
http://gltrs.grc.nasa.gov/
The above link is a little tough to get exactly what you want, since NASA has papers on nearly every subject you can imagine, but it's an amazing source of free papers written by some of the best minds in the various industries.
I have a similar problem, and was wondering if you found a solution. In my case, the speed is very low but we need a system running for very long time and a severe constraint on max friction. Magnetic bearings and Superconducting magnetics bearings cannot be used in our case.
Any pointer to manufacturers of bearings for cryogenics application would be welcome.
www.bardenbearings.com
They have both full ceramic and Hybrid bearings.
You might give them a call and see what they have to offer.
http://w
