astable ajustable timer to pulse 30 secs to 5 mins question
I am looking for a schematic thats simple using a pot to adjust my timing.. final output would look like this
______|______|_______
30secs 30secs 30secs
ajustable to
_______________|_________________|_________________
3mins 3mins 3mins
the pulse can vary but has to be relatively short, .5 secs is ok. i have 5 volts dc as power supply and think a 555 will work but I dont know the best way to do it..
can anyone help me? many thanks in advance if you can..
james
ajustable to
3mins 3mins 3mins
james
RE: astable ajustable timer to pulse 30 secs to 5 mins question
Did you have a chance to take a look at a 555 timer application data sheet? Try looking at www.national.com and look up the LM555 timer. Perhaps something there might give you some ideas.
Keep us posted!
Better accuracy requires crystal clock -- divider.
<nbucska@pcperipherals.com>
in astable configuration the pulse period is equal to
T=.693*C*(2Ra+Rb)
where Ra is resistor between pin number 6 and 7
and Rb is resistor between pin number 7 and 8 or Vcc (+5)
high time=.693*C*(Ra+Rb)
low time =.693*C*Ra
you can make very large duty cycle with choosing Ra a very low value and Rb many times greater than Ra
then you can invert the signal with a simple not gate
(74LS04).
if you still don't understand how circuit works let me know.
