Reference set advice?
Our current policy is to only use one reference set (SOLID). When creating left and right handed versions we currenty create 2 ref's and wave link in a mirrored version of ref 1 into ref 2.
However, creating a LH and RH ref set does seem to be very nice way of creating handed version. It also allows easy adding of component to assemblies.
Any comments or views much appreciated
RE: Reference set advice?
-Dave
PLM Exchange
http://plmexchange.net
http://groups-beta.google.com/group/NX_CAX/
Would something like this cause a problem though!
h
Ref 2 would be used twice but ref one would have a mirrored version,would wavel inking not cause a problem as its part of a sub-assembly?
Forgive me If I'm over complicating it ::
WAVE does not require an assembly to link geometry. You need to enable WAVE Mode if you have the license. Tools -> Assembly Navigator -> WAVE Mode. To use WAVE after you have enabled it, go to the Assembly navigator and right click on the part and select WAVE -> ... Pick what you want to do. Copy geometry to component, part, new part, and other options.
-Dave
PLM Exchange
http://groups.google.com/group/NX_CAX/
-Dave
PLM Exchange
Your advice makes sense, but we don't have the license to do that. The BOM presents no problems as long as the levels are properly set.
Good info, though!
Many thanks to all of you for your help and comments.
Mark Noyce
Senior Design Engineer/CAD co-ordinator
Mark Noyce
