measure between
measure between
Hi, can I export to excel results of measure between or item?
thanks
thanks
RE: measure between
just modify the script you have to extract this measure to txt file
RE: measure between
RE: measure between
If you want to do with with a design table, you'll have to add parameters for each of the measurements. When you create the parameter, right-click in the value field (after the name field) and chose the Measure Between option.
RE: measure between
its a good idea, I tried but it end with:..."Relation DesignTable.1 cannot be activated because on of its output is a referenced constraint".... the design teable comes into deactivated state after creation..:o(
